WSJT-X 2.0, OH3NE, ja viimeinen WSJT-X 2.1.2
Lähetetty: 29.04.2020 16:15
Lahden Radioamatöörikerhon Keskustelufoorumi
http://oh3ac.fi/palsta/
Installation packages for WSJT-X 2.1.2
Windows:
Version 2.1.2: wsjtx-2.1.2-win32.exe. (32-bit Vista, Win 7, Win 8, and Win 10).
Version 2.1.2: wsjtx-2.1.2-win64.exe. (64-bit Vista, Win 7, Win 8, and Win 10).
Linux:
Installation instructions for Linux can be found here in the User Guide. Download the package file appropriate for your system, from the list below. (Versions installable with "apt-get" and "yum" will be made available as soon as our package maintainers create the packages.)
Version 2.1.2
Debian, Ubuntu 18.04 LTS, ... (32-bit): wsjtx_2.1.2_i386.deb
Debian, Ubuntu 18.04 LTS, ... (64-bit): wsjtx_2.1.2_amd64.deb
Fedora 29, RedHat, ... (32-bit): wsjtx-2.1.2.i686.rpm
Fedora 29, RedHat, ... (64-bit): wsjtx-2.1.2.x86_64.rpm
Raspbian Stretch, ARMv6, ... : wsjtx_2.1.2_armhf.deb
Note: these packages are unlikely to install properly on Linux distributions with required dependencies at lower versions than those on the named distributions. In such cases building from source is the correct way to install WSJT-X 2.0.
Macintosh macOS:
Installation instructions for version 2.1.2 can be found here in the User Guide.
Version 2.1.2 for OS X (macOS) 10.10 through 10.15: wsjtx-2.1.2-Darwin.dmg
Source Code:
WSJT-X is licensed under the terms of Version 3 of the GNU General Public License (GPL). Development of this software is a cooperative project to which many amateur radio operators have contributed. If you use our code, please have the courtesy to let us know about it. If you find bugs or make improvements to the code, please report them to us in a timely fashion.
Build and installation instructions are in the INSTALL file inside the tarball.
Source code for WSJT-X 2.1.2: wsjtx-2.1.2.tgz
©2001-2020 by Joe Taylor, K1JT
