xBitx - QRP-radio,10 W, 2025
Lähetetty: 08.01.2025 20:11
https://youtu.be/cQmB9t5UHno?t=1529
https://www.hfsignals.com
https://www.hfsignals.com/index.php/zbitx/
The zBitx breaks new barriers in price performance charts with a world class SDR with 24 bit ADC, hybrid crystal roofing filter, robust 10 watt PA and really fast Raspberry Pi Zero 2 W.
Work the world with a few watts on 80M to 10M on two LiPo Cells! The zBitx is the most powerful SDR with 64-bit Raspberry Pi Zero 2W inside it. Work CW, SSB, FT8, log your contacts and operate with the smooth, noiseless electronic T/R and filter switching, temperature compensated, low noise oscillator.
The zBitx has all the features and the same software that powers the sBitx radios in a smaller, less expensive radio. Explore FT8, FreeDV, QSSTV, all without any wires and computer connections!
Size: 156mm x 80mm x 35mm (including the battery case)
Weight: 415 grams including two LiPo batteries
Display: 480×320 resistive touch screen display with an independent Raspberry Pico front panel controller.
Software: Fully open sourced and available on https://github.com/afarhan
Hardware: Hybrid superhet, open source circuit with full description
Frequency Coverage: All international ham bands from 80M to 10M
Power: 5 watts on all bands except reduced power on 15M, 12M and 10M bands.
Power Supply: 6V to 9V.
Receive Current consumption: 300 mA
Transmit Current consumption: 1.5 to 3A (depending on the Drive settings)
Modes: USB/LSB/AM/CW/CW-Reverse/FT8/Digital modes (with FlDigi)
Preloaded Apps: FreeDV, QSSTV, Fldigi and more are coming
