Yaesu FT-897 -retkiamatööriradio
Lähetetty: 14.03.2019 12:02
Lahden Radioamatöörikerho ry näyttää saaneen Yaesu FT-897:n. Alempana siihen liittyvää asiaa ja näkemyksiä. Alla olevissa linkeissä oleva F-897D eroaa jonkin verran Lahden Radioamatöörikerho ry:n lahjoituksena saamsta FT-897:stä.
FT-897:m service manual
http://www.arcticpeak.com/files/FT-897% ... lement.pdf
Yaesu FT-897D - Is It Still A Great Portable Transceiver?
https://www.youtube.com/watch?v=tfnvbA0Ddxo
YAESU FT 897D - Short Introduction
https://www.youtube.com/watch?v=mrHo017FZ3Q
Setting up the FT-897D Part 1
https://www.youtube.com/watch?v=rx0QiewUQGc
Setting up the FT-897D Part 2
https://www.youtube.com/watch?v=3XSBCG0ePyM
Недоработанный FT-897 и FT-991. Сравнение работы в полях. Два разных поколения Yaesu.
https://www.youtube.com/watch?v=jh_R_xfaBEI
Yaesu FT-897 Operating Manual
https://www.manualslib.com/manual/99096 ... t-897.html
http://www.radiomanual.info/schemi/YAES ... 7_user.pdf
Lisävarusteet:
FP-30External AC Power SupplyFP-1030AExternal AC Power Supply (25A)
FP-1023ACompact Power Supply (23A; U.S.A. only)
FNB-78Ni-MH Battery Pack (13.2 V, 4500 mAh)
PA-26B/C/UNi-MH Battery Charger
CD-24Ni-MH Battery Charger Adapter
YF-122SCollins SSB Filter (2.3 kHz/4.7 kHz: -6 dB/-66 dB)
YF-122CCollins CW Filter (500 Hz/2 kHz: -6 dB/-60 dB)
TCXO-9TCXO Unit (±0.5 ppm)
FC-30External Automatic Antenna TunerATAS-120Active-Tuning Antenna System
ATBK-100VHF/UHF Antenna Base/Counterpoise Kit
MMB-80Mounting Braket
VL-1000Solid-State Linear Amplifier
MD-200A8XDesktop MicrophoneMH-36E8JDTMF Microphone
CT-62CAT Interface Cable
CT-39APacket Cable
CT-58BAND DATA Cable
