Ham Pi
Erilaisiin tietokoneelle asennettaviin apuohjelmiin liittyvä keskustelu.
Ham Pi
ViestiKirjoittaja oh2op » 05.02.2022 17:36
https://github.com/dslotter/HamPi
Past Version
Version 2 of Raspberry Pi Ham Radio Image by W3DJS
General Ham Radio Applications
HamLib - Ham Radio Control Libraries
grig - graphical user interface to the Ham Radio Control Libraries
CHIRP - Radio Programming Software
APRS Message App for JS8Call - GUI to send APRS messages via JS8Call
QTel - EchoLink client
QSSTV - Slow Scan TV (e.g. "Fax")
Gpredict - Satellite prediction
FreeDV - Free digital voice vocoder
BlueDV - Client for D-Star and DMR
WsprryPi - WSPR software
ADS-B Flight Tracking Software
Pi3/4 Stats Monitor - by W1HKJ
VOACAP - HF propagation prediction
GPS Support
Auto WiFi Hotspot - Automatically turn your Pi into a WiFi hotspot when in the field!
wxtoimg - NOAA weather imaging software
twHamQTH - an online callsign look up program
twclock - a world clock and automatic ID for amateur radio operators
acfax - Receive faxes using your radio and sound card
colrconv - convers client with sound and ncurses color support
d-rats - A communication tool for D-STAR
fbb - Packet radio mailbox and utilities
gcb - Utility to calculate long and short path to a location
glfer - Spectrogram display and QRSS keyer
Xdx is a DX-cluster client
DXSpider - DX Cluster Server
fccexam - Study tool for USA FCC commercial radio license exams.
gnuais / gnuaisgui - GNU Automatic Identification System receiver
hamexam - Study guide for USA FCC amateur radio (ham radio) license examinations.
hamfax - Qt based shortwave fax
inspectrum - tool for visualising captured radio signals
predict-gsat - Graphical Predict client
splat - analyze point-to-point terrestrial RF communication links
wwl - Calculates distance and azimuth between two Maidenhead locators
Antenna Ham Radio Applications
antennavis - Antenna Visualization Software
gsmc - A GTK Smith Chart Calculator for RF impedance matching
nec2c - Translation of the NEC2 FORTRAN source code to the C language
xnecview - NEC structure and gain pattern viewer
yagiuda - software to analyse performance of Yagi-Uda antennas
Digital Mode Ham Radio Applications WSJT-X - Weak Signal (FT8, FT4, etc.) by W1JT
GridTracker - Graphical mapping companion program for WSJT-X or JTDX
JTDX - Alternate client for Weak Signal (FT8, FT4, etc.)
JS8Call - Messaging built on top of FT8 protocol by KN4CRD
JS8CallTools - Get Grid coordinates using GPS
(FLDigi is in its own section below.)
gnss-sdr - GLONASS satellite system Software Defined Receiver
linpsk - amateur radio PSK31/RTTY program via soundcard
multimon - multimon - program to decode radio transmissions
multimon-ng - digital radio transmission decoder
psk31lx - a terminal based ncurses program for psk31
twpsk - a psk program
Software Defined Radio
CubicSDR - Software Defined Radio receiver
cutesdr - Simple demodulation and spectrum display program
GQRX - Software defined radio receiver
SDRAngel - SDR player
lysdr - Simple software-defined radio
quisk - Software Defined Radio (SDR)
SoapyAudio - Soapy SDR plugin for Audio devices
SoapyHackRF - SoapySDR HackRF module
SoapyMultiSDR - Multi-device support module for SoapySDR
SoapyNetSDR - Soapy SDR module for NetSDR protocol
SoapyRemote - Use any Soapy SDR remotely
SoapyRTLSDR - Soapy SDR module for RTL SDR USB dongle
SoapySDR - Vendor and platform neutral SDR support library
SoapySDRPlay - Soapy SDR module for SDRPlay
Support for RTL-SDR
Support for SDRPlay SDR
Support for HackRF SDR
APRS Applications
Xastir - APRS GUI client / Digipeater / Igate
YAAC - Yet Another APRS Client
DireWolf - Software "soundcard" AX.25 packet modem/TNC and APRS encoder/decoder
aprsdigi - digipeater for APRS
aprx - APRS Digipeater and iGate
soundmodem - Sound Card Amateur Packet Radio Modems
FLDigi Application Suite from W1HKJ flrig - Rig Control program which interfaces with fldigi
fldigi - Digital Modes Communications
flaa - RigExpert Antenna Analyzer Control Program
flamp - File transmissions via Amateur Multicast Protocol
flarq - ARQ data transfer utility for fldigi
flcluster - Telnet client to remote DX Cluster Servers
fllog - Logbook application which can use same data file as fldigi
flmsg - Editor for ICS 213 Forms
flnet - Net Control Assistant for Net Activities (Check-In Application)
flpost - NBEMs post office
flwrap - File encapsulation and compression for transmission over amateur radio
flwkey - Winkeyer (or clone) control program for K1EL Winkeyer series
Logging Applications
TrustedQSL - LotW client
CQRlog - Ham Radio Logging Application
PyQSO - Logging software (written in Python)
KLog - The Ham Radio Logging program
tlf - console based ham radio contest logger
tucnak2 - VHF/UHF/SHF Hamradio contest log version 2
twlog - basic logging program for ham radio
wsjtx_to_n3fjp - Logging adapter to allow WSJT-X to log to N3FJP
xlog - GTK+ Logging program for Hamradio Operators
WinLink Applications
Pat WinLink - WinLink for Raspberry Pi (and other platforms)
ARDOP support for Pat WinLink
ARDOP-GUI - Provides graphical representation of ARDOP connections
Find ARDOP - Retrieves local ARDOP sources by KM4ACK
AX25 support for Pat WinLink
PMON - a PACTOR® Monitoring Utility for Linux
Morse Code Applications
aldo - Morse code training program
cw - sound characters as Morse code on the soundcard or console speaker
cwcp - Text based Morse tutor program
xcwcp - Graphical Morse tutor program
cwdaemon - morse daemon for the serial or parallel port
ebook2cw - convert ebooks to Morse MP3s/OGGs
ebook2cwgui - GUI for ebook2cw
morse - training program about morse-code for aspiring radio hams
morse2ascii - tool for decoding the morse codes from a PCM WAV file
morsegen - convert file to ASCII morse code
qrq - High speed Morse telegraphy trainer
twcw - sends morse code via the sound card or serial card (Needs RTC installed)
xdemorse - decode Morse signals to text
rscw - Receive CW through Soundcard
*** Ham Radio Wallpaper also included in image ***
Palaa sivulle “Ohjelmat”
Käyttäjiä lukemassa tätä aluetta: Ei rekisteröityneitä käyttäjiä ja 3 vierailijaa
