https://wfview.org | vesiputousnäytöllinen kauko-ohjaus: Icom & Xiegu
Erilaisiin tietokoneelle asennettaviin apuohjelmiin liittyvä keskustelu.
ViestiKirjoittaja oh2op » 31.08.2023 00:49
https://wfview.com
wfview provides the user with controls that may be comfortably operated from a keyboard, mouse, or touch screen interface.
On rigs with built-in network interfaces (such as the IC-705, IC-905, IC-7610, IC-7850, IC-R8600, IC-9700, and Xiegu X6100), live audio streaming is available for both receive and transmit. Special care was taken in the creation of the network code for very low latency audio — ideal for general QSOs as well as time-sensitive modes such as FT8 and JT65.
On the IC-7300 (and other non-network rigs), wfview can serve as a USB to Ethernet “bridge”, connecting the IC-7300 to the network for remote control and live streaming full-duplex audio using another instance of wfview on a remote computer.
The server can be a humble Raspberry Pi or a normal desktop computer.
wfview has been developed with an eye towards compatibility. Even though our target platform consists of modern-era transceivers, wfview’s command dictionary is focused on commands with the most compatibility. Many of Icom’s transceivers from the last 20 years will work to some degree with wfview, and we are always adding more.
The user may select between the current desktop theme, an included “dark” theme (qdarkstylesheet), or a user-specified qt stylesheet. All colors can be customized via the built-in User-Defined Color Editor or by specifying a custom stylesheet.
GNU/Debian Linux Re: https://wfview.org
ViestiKirjoittaja oh2op » 31.08.2023 01:03
https://wfview.org :ssa oleva ohjelma on myös GNU/Debian Linuxin ohjelmahakemistossa. Terminaali- eli päätetilassa ohjelman voi asentaa valvojatasolla käskyllä
sudo apt install wfview
Näin ei ajaudu erilaisiin Windows 10-, Windows 11- tai Windows 12-päivityksiin, kun käyttää Linuxia. Lahden Radioamatöörikerhon kahvihuoneen pöydällä on DVD:inä Red Hat -heimoinen, .rpm -tiedostopaketteja käyttävä Open SuSE Linux 64-bittisenä moniydinsuorittemisille tietokoneille sekä Debian-heimoinen Antix 64-bittisenä moniydinsuorittemisille tietokoneilla ja 32-bittisenä yksiydinsuorittimisille tietokoneille. 64-bittistä ei voi käyttää 32-bittisessä koneessa, mutta 32-bittistä voi käyttää moniydinsuorittimisillissä tietokoneissa.
Pääasiassa käyteyt tietokoneet, mitkä liikkuvat Patinassa ja Lanttilassa ovat varhaisia kaksiytimisiä, ja siis 64-bittisiä tietokoneita.
Myös Debian-heimoinen ja Ubuntu-sukuinen Linux Mint on melko hyvä graafiselta käyttöliittymältään.
Palaa sivulle “Ohjelmat”
Käyttäjiä lukemassa tätä aluetta: Ei rekisteröityneitä käyttäjiä ja 4 vierailijaa
