xBitx - QRP-radio,10 W, 2025
ViestiKirjoittaja oh2op » 08.01.2025 20:11
https://youtu.be/cQmB9t5UHno?t=1529
https://www.hfsignals.com
The zBitx breaks new barriers in price performance charts with a world class SDR with 24 bit ADC, hybrid crystal roofing filter, robust 10 watt PA and really fast Raspberry Pi Zero 2 W.
Work the world with a few watts on 80M to 10M on two LiPo Cells! The zBitx is the most powerful SDR with 64-bit Raspberry Pi Zero 2W inside it. Work CW, SSB, FT8, log your contacts and operate with the smooth, noiseless electronic T/R and filter switching, temperature compensated, low noise oscillator.
The zBitx has all the features and the same software that powers the sBitx radios in a smaller, less expensive radio. Explore FT8, FreeDV, QSSTV, all without any wires and computer connections!
https://www.hfsignals.com/index.php/zbitx/
Size: 156mm x 80mm x 35mm (including the battery case)
Weight: 415 grams including two LiPo batteries
Display: 480×320 resistive touch screen display with an independent Raspberry Pico front panel controller.
Software: Fully open sourced and available on https://github.com/afarhan
Hardware: Hybrid superhet, open source circuit with full description
Frequency Coverage: All international ham bands from 80M to 10M
Power: 5 watts on all bands except reduced power on 15M, 12M and 10M bands.
Power Supply: 6V to 9V.
Receive Current consumption: 300 mA
Transmit Current consumption: 1.5 to 3A (depending on the Drive settings)
Modes: USB/LSB/AM/CW/CW-Reverse/FT8/Digital modes (with FlDigi)
Preloaded Apps: FreeDV, QSSTV, Fldigi and more are coming
Viimeksi muokannut oh2op, 08.01.2025 20:50. Yhteensä muokattu 1 kertaa.
FT8 Re: xBitx - QRP-radio,10 W, 2025
ViestiKirjoittaja oh2op » 08.01.2025 20:48
The zBitx is a complete FT8 station. Just switch it on and start working FT8! Forget about the mess of wires, audio level settings and confusing settings. Just tune to the FT8 frequencies and tap on the callsign to complete a QSO!
Käyttäjiä lukemassa tätä aluetta: Ei rekisteröityneitä käyttäjiä ja 34 vierailijaa
