Troposfääriä 135 km:n päähän
ViestiKirjoittaja oh2op » 07.04.2025 18:29
https://www.tekniikkatalous.fi/uutiset/ ... parit:5ca1
https://puolustusvoimat.fi/documents/19 ... 2556134860
38 / 78
tai sitten tavallinen havainto. https://defencehub.live/threads/a-new-r ... ine.10485/
At the first stage, specialists checked the technical parameters of each part of the Mineral-U complex separately, in particular, the transmitter power, receiver sensitivity, delay time, and technical properties.
During the second stage, the equipment was installed on the chassis, after which it was tested as a whole: target detection range, operation in a wide range of frequency ranges, complex mobility, and other parameters.
RLK Mineral-U was developed by the Research Institute of Radar Systems Kvant-Radar. This radar complex detects and classifies surface objects at a distance of 500-600 km thanks to a passive channel, it can also conduct additional reconnaissance using an active channel. Mineral-U was first demonstrated to the general public on August 24 during a military parade in Kiev dedicated to the 30th anniversary of Ukraine's independence.
https://en.m.wikipedia.org/wiki/R-360_Neptune
Käyttäjiä lukemassa tätä aluetta: Ei rekisteröityneitä käyttäjiä ja 26 vierailijaa
