Wouxuneiden käyttöohjeet ja ohjelmointietokoneohjelmat
ViestiKirjoittaja oh2op » 25.06.2016 04:39
http://wouxun.com/resource.aspx
KG-UVD1P Programming Software , V2.14 2,571KB 2016-06-20
KG-UV66 User Manual 10,044KB 2016-06-14
KG-889 User Manual 22,229KB 2016-06-10
USB Driver for Windows 10 20,364KB 2016-06-07
KG-UV899 User Manual 19,040KB 2016-04-19
KG-UV9D(Plus) Folding Instruction 1,267KB 2016-03-01
KG-UV8D(Plus) Folding Instruction 1,201KB 2016-03-01
KG-UV9D(Plus) User Manual 15,261KB 2016-02-27
KG-UV8D(Plus) User Manual 26,421KB 2016-02-27
KG-UV6D(66-88/400-480MHz)Programming Software 1,432KB 2016-02-25
KG-UV9D(Plus) Programming Software 1,698KB 2016-01-23
KG-UV8D(Plus) Programming Software 1,728KB 2016-01-23
KG-UV6D(66-88/136-174MHz)Programming Software 1,433KB 2016-01-07
KG-859 Programming Software 730KB 2015-11-23
KG-UV9D User Manual 49,296KB 2015-11-21
KG-UV9D Programming Software 1,912KB 2015-07-29
KG-UV899 Programming Software 1,290KB 2014-09-12
KG-UV8D User Manual 16,491KB 2014-08-29
KG-UV8D Programming Software 1,607KB 2014-08-21
KG-UV950P User Manual 29,774KB 2013-12-24
KG-UV950P Programming Software , Step 2.5KHz 1,397KB 2013-12-24
KG-UV950P Programming Software , Step 5KHz 1,396KB 2013-12-23
KG-819 , 66-88MHz , Programming Software 1,318KB 2013-12-13
KG-816 , 66-88MHz , Programming Software 1,329KB 2013-12-13
KG-UVA1 Programming Software 842KB 2012-12-22
KG-869/889 , 66-88MHz , Programming Software 1,935KB 2012-12-22
KG-869/889 Programming Software 1,935KB 2012-12-22
KG-UV920P-E User Manual 30,494KB 2012-12-22
KG-UV920P User Manual 29,099KB 2012-12-22
KG-UV6D User Manual 19,931KB 2012-12-22
KG-UV920P-E Programming Software 1,593KB 2012-12-22
KG-UV920P-A Programming Software 1,371KB 2012-12-22
KG-UV920P Programming Software 1,593KB 2012-12-22
KG-UV6D Programming Software , Step 5KHz 1,432KB 2012-12-22
KG-UV6D Programming Software , Step 2.5KHz 1,432KB 2012-12-22
KG-UVD1P User Manual 16,436KB 2011-04-03
KG-801E(the popular) User Manual 13,450KB 2010-10-11
KG-833(the popular)C2 Programming Software 5,608KB 2010-10-08
KG-833(the popular) User Manual 3,993KB 2010-09-23
KG-703E/801E , 66-88MHz , Programming Software 1,395KB 2010-09-01
KG-UVD1P Programming Manual 2,150KB 2010-08-31
KG-639E/833/929 , 66-88MHz , Programming Software 1,294KB 2010-08-31
KG-703E(the popular)C2 Programming Software 2,698KB 2010-08-31
KG-689E/699E , 66-88MHz , Programming Software 1,268KB 2010-08-31
KG-703E/801E(the popular) Programming Software 1,395KB 2010-08-31
KG-689E/699E(the popular) Programming Software 1,268KB 2010-08-31
KG-689E(the popular)C2 Programming Software 2,700KB 2010-08-31
KG-669E/679E(the popular) Programming Software 1,258KB 2010-08-31
KG-679E(the popular)C2 Programming Software 2,698KB 2010-08-31
KG-659E , 66-88MHz , Programming Software 1,367KB 2010-08-31
KG-669E(the popular)C2 Programming Software 2,698KB 2010-08-31
KG-659E(the popular) Programming Software 1,366KB 2010-08-31
KG-639E/833/929(the popular) Programming Software 1,294KB 2010-08-31
KG-639E(the popular)C2 Programming Software 5,608KB 2010-08-31
Getting Ready to Program Tutorial 225KB 2010-08-24
Setting the Port Assignment Guide Document 344KB 2010-08-24
Installing USB Driver Instruction 237KB 2010-08-24
USB Driver Software for New Cable 3,609KB 2010-08-10
KG-619 Programming Software 1,998KB 2010-08-02
KG-689E(the advanced) Programming Software 4,304KB 2010-07-28
How to Tell the Exact Configuration of the Transceiver 226KB 2010-07-20
KG-3000 Programming Software 336KB 2010-06-15
KG-659E(the upgrade) Programming Software 2,013KB 2010-06-12
KG-703E(the upgrade) Programming Software 4,311KB 2010-06-12
KG-703E(the advanced) Programming Software 2,006KB 2010-06-12
KG-659E(the advanced) Programming Software 2,002KB 2010-06-09
KG-689E(the upgrade) Programming Software 2,013KB 2010-06-09
KG-639E(the upgrade) Programming Software 2,013KB 2010-06-07
KG-679E(the advanced) Programming Software 2,003KB 2010-06-07
KG-679E(the upgrade) Programming Software 2,013KB 2010-06-07
KG-833(the upgrade) Programming Software 2,013KB 2010-06-07
KG-669E(the advanced) Programming Software 2,003KB 2010-06-02
KG-669E(the upgrade) Programming Software 2,374KB 2010-06-02
KG-699E(the advanced) Programming Software 4,304KB 2010-06-02
KG-699E(the upgrade) Programming Software 1,951KB 2010-06-02
USB Driver Software for Old Cable 3,686KB 2010-05-31
KG-819 User Manual 5,297KB 2010-05-29
KG-816 Programming Software 1,330KB 2010-05-29
KG-819 Programming Software 1,316KB 2010-05-29
KG-639E(the popular) User Manual 3,991KB 2009-12-09
KG-659E(the popular) User Manual 5,347KB 2009-12-09
KG-669E(the popular) User Manual 13,450KB 2009-12-09
KG-679E(the popular) User Manual 13,450KB 2009-12-09
KG-689E(the popular) User Manual 14,708KB 2009-12-09
KG-699E(the popular) User Manual 14,708KB 2009-12-09
KG-689E(the upgrade) User Manual 16,765KB 2009-12-09
KG-699E(the upgrade) User Manual 8,246KB 2009-12-09
KG-703E(the upgrade) User Manual 10,440KB 2009-12-09
KG-639E(the advanced) User Manual 2,493KB 2009-12-05
KG-659E(the advanced) User Manual 5,332KB 2009-12-05
KG-669E(the advanced) User Manual 6,798KB 2009-12-05
KG-679E(the advanced) User Manual 13,227KB 2009-11-30
KG-689E(the advanced) User Manual 7,228KB 2009-11-30
KG-699E(the advanced) User Manual 14,337KB 2009-11-30
KG-816 User Manual 13,472KB 2009-10-20
KG-703E(the popular) User Manual 13,450KB 2009-12-09
KG-639E(the upgrade) User Manual 2,256KB 2009-12-09
KG-659E(the upgrade) User Manual 8,203KB 2009-12-09
KG-669E(the upgrade) User Manual 7,750KB 2009-12-09
KG-679E(the upgrade) User Manual 8,500KB 2009-12-09
KG-UV*D
ViestiKirjoittaja oh2op » 25.06.2016 05:01
KG-UV*D
KG-UV6D (2012-2016)
KG-UV6D Programming Software , Step 2.5KHz 1,432KB 2012-12-22 http://wouxun.com/resource.aspx
KG-UV6D Programming Software , Step 5KHz 1,432KB 2012-12-22 http://wouxun.com/resource.aspx
KG-UV6D User Manual 19,931KB 2012-12-22 http://wouxun.com/resource.aspx
KG-UV6D(66-88/136-174MHz)Programming Software 1,433KB 2016-01-07 http://wouxun.com/resource.aspx
KG-UV6D(66-88/400-480MHz)Programming Software 1,432KB 2016-02-25 http://wouxun.com/resource.aspx
YouTube: Wouxun KG UV6D Ham Radio Review & Programing https://www.youtube.com/watch?v=MJpR4l0g1O0
KG-UV8D (2014-2016)
KG-UV8D Programming Software 1,607KB 2014-08-21 http://wouxun.com/resource.aspx
KG-UV8D User Manual 16,491KB 2014-08-29 http://wouxun.com/resource.aspx
KG-UV8D(Plus) Folding Instruction 1,201KB 2016-03-01 http://wouxun.com/resource.aspx
KG-UV8D(Plus) Programming Software 1,728KB 2016-01-23 http://wouxun.com/resource.aspx
KG-UV8D(Plus) User Manual 26,421KB 2016-02-27 http://wouxun.com/resource.aspx
YouTube: Wouxun KG-UV8D Cross-Band Repeater https://www.youtube.com/watch?v=y4UCx1sFor8
X-DIRPT 462,700 MHz ↑ 142,300 MHz ↓ (05:30/11:18), Motorola => Wouxun KG-UV8D => Baofeng UV-5R
X-TWRPT 462,700 MHz ↑ ↓ 142,300 MHz ↑ ↓ (07:15/11:18), Motorola <=> KG-UV8D <=> Baofeng UV-5R
YouTube: Do you have these issues with Baofeng Wouxun TYT radios? https://www.youtube.com/watch?v=Jmv--rKxJ14
Käyttäjiä lukemassa tätä aluetta: Ei rekisteröityneitä käyttäjiä ja 4 vierailijaa
